Make sure your coolant is full.
Did yesterday, it wasn't, but now is.
Good luck getting the upper bushings out.
Coolant is an important part of the cooling system. We are getting more HP out of it now so you need to make sure it is full. Also I would consider washing out your radiator at min. I like to pull them out and wash them out Heavy duty with the nozzle on the garden hose. Reds truck used to run 220+ with the a/c on and now will run 180 all day.
I heard you are looking for a Detroit for a 14 bolt. I've got one for sale. Here's the deal. It's from a 1960's Eaton rearend out of a chevy 3/4 ton. I'm not sure if you know much about the Eaton, but it was the predecessor to the 14 Bolt. The Detroit's for these two axles are interchangeable. The only difference is the spline count on the axle shafts. the 14 is 30 spline and I think the Eaton is 17 spline. Well, I've got a set of axle shafts too, so that's not a problem.
Here's a thread on the Eaton's. Guys run the 17 spline shafts with 44's all the time.
http://www.pirate4x4.com/forum/showthread.php?t=771317
I've also got a thick Yukon 4.88 R&P for the 14 bolt. I'd do a package deal for $500 for the locker, shafts, and the R&P. I can't set up R&P's, but I could help you set the backlash on your current R&P after you install the detroit.
I only want to sell them as a package. Otherwise I've got a guy who wants to trade me the Detroit for a set of Dana 60 shafts and lockouts.
I've also got a Ford HP 44 with 4.88's and a detroit, high steer, and all new brakes and ball joints, and a Ford NP205. I'd make you a deal on those too if you wanted to do a 203/205 doubler and run the High Pinion front axle. The spring pad width is the same on the ford and chevy's, so it should bolt in.
Noooo........Still drove it home after all of that though. And apparantly there was so much sand in my hub cap, it flew off on the way home. Im kinda pissed about that.
Noooo...............
Sorry to hear about the bad day, they happen, build it up better and whoop that river next time![]()
