As much as i love that look, not sure its my exact cup of tea ( transit wheels and chrome ). I dig the camper/cover's slanted windows though, and the color.
For sure.As much as i love that look, not sure its my exact cup of tea ( transit wheels and chrome ). I dig the camper/cover's slanted windows though, and the color.
Would also be nice to have if I ever advanced my cam timing in the future. After reading a few posts lately from @folkenheath, it seems like not a bad idea if and when the motor gets some speed parts tossed at it.
That's a nice tool, but not accurate enough, you also have a high probability of bending it with the wedge style combustion chamber of all 2 valve per cylinder Chevy V8s that I am aware of, as the spark plug is at an acute angle relative to the piston top. Unlike a hemi or DOHC engine where the spark plug goes in from the top through the valve cover. If you are looking for TDC the piston will kind of hover at the top for a few degrees or more, which is not accurate enough.
I use a sold brass one with a hole in it, vents the compression. You set the piston at around 10 degrees before TDC, then screw the stop in until it contacts the piston. Now, rotate the engine both ways by hand until it contacts the stop. Mark each place on the balancer or pointer with a marker or tape. Then the point exactly in between there is TDC once you remove the piston stop. This is much more accurate. Looks like this...
I also have one like this since sometimes that one is rubbing on the valve...
Its not going to fix itselfYou're motivating me to give my C10's tailgate some attention. It doesn't close as nice as yours!
ha.The biggest problem with mine is the latches like to squeak so I have to lube them up on occasion.
