Trans is all buttoned up for now and no pan leaks after a couple days so thats good. Also found a local guy who came recommended by 4-5 people, to have build a new 4l60, or 4l65 for me. I told him i wanted to be able to party, and he said no problem at all. Might be some time before i can afford it, so hopefully this one lasts through the summer.
I also decided to move the main terminator harness behind the motor and through the firewall there. I was having some concern with how it ran past the exhaust on that side. This way its neater in the engine bay, and also i dont have to worry about heat . It tucked behind the heater assembly, and up to the ECM easily. I also took a stab at this plastic sticker togetherer i got online. It just burns these staples into the plastic, they are shaped for flat, inside corner, and outside corner. I still have a a small corner piece to make, and also try and stick the strip that flexes on there. It also has a pronged flat attachment that looks like an oil painting knife, and it melts the seam you create when joining the two pieces.
Pretty neat tool, definitely takes a little getting used to in terms of how hot to to get them, and how to insert them. turned out better than i needed it too , and cheaper than buying an insert from somewhere. I didnt know that the staples break off by hand and i went and snipped them all, so im going to have to take the little cut off wheel to them instead.
