It’s a Qjet, it’s warped
20” means the rings are probably good. Probably sucking oil through the pcv into the intake
pcv valve is on the list of things to get. it rattles but might still be bad its most likely original...
p.s im growing a fond hate for all the smog vacuum crap thats always in my way...
Aircare is gone in BC No!?
the carb also has a nic in the secondary bore so I'm gonna swap it for another one..I always advocate for connecting vacuum advance to manifold vacuum, NOT ported vacuum.
Does the PCV air tube still line up with the air filter housing?
Are you still going to run the hot air choke pipe thingy?
If you can keep the stove pipe functional then it may help warm ups on cold and humid days.
I thought the flapper worked off of a temperature controlled vacuum switch in the thermostat housing? As in run vacuum from carb to switch, then to the flapper valve so that the switch is closed under a certain coolant temp and closes the flapper valve. Then as the coolant temp comes up the switch opens as the flapper swings open.I also just realized my stove pipe is hooked up but the flap won't close without vacuum from the carb if I remember correctly. It's tied into the manifd vacuum for the vacuum secondaries, and is no longer there since I have mechanical secondaries on this carb. hmm some things to work on for sure.
