I remember my 64 C10 in high school had a flapper valve in the exhaust, a little piece between the manifold and pipe. It had the thermo coil like a choke. Damn thing got installed the wrong way and was forced closed. Took me over a year to figure out the cause of my engine overhearing.
This 79 has that same thing .
Since I've removed the smog stuff this is now just freeballin down there without any vacuum to orientate it. I'm assuming the way I have it is open.. the pipe after is hot so It must be letting air past, id assume it'd run poor like you mentioned ,if it couldn't let the gas escape. Having one of those installed backwards must have been a tail chasing nightmare
I thought the flapper worked off of a temperature controlled vacuum switch in the thermostat housing? As in run vacuum from carb to switch, then to the flapper valve so that the switch is closed under a certain coolant temp and closes the flapper valve. Then as the coolant temp comes up the switch opens as the flapper swings open.
Ahh I was talking about the flapper valve in the air cleaner. If you are too mine went from the top of the intake about where the stove pipe vacuum thingy is, to the underside of the air cleaner, and then a vacuum line was attached to another port right beside it and that one went and T'd in-between the manifold vacuum source for the secondaries.
