Ive decided to go with the Brian tooley stage 2 cam , I figured I should check my pushrods first and order some at the same time if I need any. None were showing any bits of wear so that's good.
I also didnt know if I should order a new timing chain or dampener with the 3 bolt sprocket I'll need. So I pulled the balancer and took the cover off, chain seems good. From what I've read I should change the dampener anyway so that'll be way to go probably.
Also got around to dropping the pan and didn't find much gunk in the pan. Just a thin layer at the bottom, threw at magnet at it and nothing stuck so that's good.
The DOD kit comes with head gaskets and bolts so I'll take the heads off and check all that out and make sure I don't have any surprises there, I doubt I will but why not if I'm this far already.
My belltech drop kit showed up so the parts hoarding is continuing.
In a few weeks I'll be able to park this thing for the winter and start tearing her down.
