Long winded post. Will update when success is achieved.
Was finally able to take this for a drive. The clutch slips under heavy load. Further investigation revealed I didn’t check my clutch free play. I just assumed the internal slave I was using was ok. And it was close to ok, but not. It was applying mild pressure to the clutch fingers.
I initially tried to use my clutch from my sm465, which fits. But I ordered in a clutch for a 1999-2004 Silverado 2500 5 speed. And it fits better, but still doesn’t have any free play. But is not applying the clutch. It’s like this flywheel is about .150” too thick. It’s aftermarket and the company probably assumes the end user is responsible for checking and setting free play.
I ordered an adjustable RAM brand internal slave for my transmission from summit and it’s supposed to be here today. I have a nice end clearance H-gauge and checked over and over. And I “should” be good with this adjustable slave. Especially if I want to change engine or clutch configurations with this transmission in the future.
The rest of the truck seemed great on my small road test. Rear brakes felt awesome. And the transmission, that I didn’t build shifted what seemed good.
It’s a snowy icy mess here and road testing it was not fun. I’m glad I discovered the clutch issue though and didn't smoke it or anything. Immediately drove home and diagnosed the issue.
So here it sits. Ha
Just so anyone reading this far knows. I have a long stick out (+.400”) crankshaft from a 99-2001 6.0 in my block. If I knew it was gonna be this undesirable I would have gone to the lengths to get a short crank. I am running Mcleods billet steel flywheel made for this crank. And a gm bellhousing and used the right internal slave. But something about that flywheel is just a little fatter than what it should be.
The truth is I should have known. To check the clutch free play before install. Lesson learned. Nothing damaged. It wasn’t forcing on the crankshaft or anything, just like driving with your foot on the clutch a little.
