79 K5...Big Ray gets his chit together. Finally
Mo goodies....and a 10 h.p. sticker!
Head bolt question.
Are these torque to yield? Thinking of doing studs...
No need for studs on a mild NA small block Ray. Head bolts are not TTY so should be able to be re-used.
I don't think I've ever seen a pic of your K5 before. Maybe I missed it...I always thought you had a diesel 'burb and that was it? Anyways, the K5 looks fantastic, I'm glad to see you building it up now! :burnout:
79.
I believe it was either blue or blue and white originally.
Haven't found the rpo list yet.
getting an epidural for my bulging disc tomorrow. I did some yard work yesterday and can hardly move today. Stiff as a board....
Having shoulder repaired July 18, that will put me down for a bit.
The cam is still 2 or 3 months out. Going to do my best to have the heads ready before surgery.
Just waiting on the valve spring compressor.
When I'm done with the K5 I'm taking the 400 and dropping it in 3/4 ton burb.
After some upgrades...hehehe
Cam, heads, exhaust, and a 1000 cfm ProFlo 1.
Mo good times....
Oh yeah, it's got a 6.2 now. It'll go into my play burb.
I will whenever it needs painted.
Looks good as is for now. I had K5 models as a child, painted them blue & white like the one in Jaws 2. Used a darker blue...
Haven't gotten much done due to personal bidness
But I did just pull the drivers side head, everything looks clean so far.
The machined surfaces on the head need cleaned. Exhaust & intake surfaces.
P.s. all manually, no impacts. My shoulder is angry lol
Those pistons are clean!
I remember now some years back I douched the cylinders with wd40 and put some plugs in.
