so fire it with the converter disconnected.....
You have all that steel on the fancy rack, what are you waiting for?
you and your damn love affair with wells.....lol
K10 or 20?
Did you sell the 205 too?
If still looking magnum/titan box, don't worry about only finding a big bearing 205. You can still use a 10 or 27 spline version, you just have to bore the input of the case to accept the larger bearing. But with both the magnum and titan box, you have to tear down the case to replace the input shaft anyways...so it's just one extra step to bore the case is all. And usually the 10/27 spline 205's are plenty and usually cheaper too...just food for thought.
Hero case is beyond bitchin, but kinda pricy. Though I hear what you are saying as in the end the titan/magnum is not a crazy amount of money away from it
I always thought the blazer should be left alone so I support that idea.
How about an atlas?
Yeah, I forgot that was an option too. Not my preferred way to go but doable. Even going that route isnt too far from the hero case. My only concern is support for the Hero 10 years from now.
I contacted AA and they did not recommend an atlas due to the power and weight of my set up.
What I'd really love to do is either a 203 mated to a Lomax 205 or even possibly a NWF Eco Box in front of a Lomax 205. The Lomax units are hard to come by nowadays but i see one surface a couple times a year on various forums and they usually go for around $2,000. Stupid beefy and 3:1 low in main case so a 203 in front would give you a great 4 spd option. Eco box in front would really be more like a 3 spd since it's already 2.72 but it would definitely be lighter and possibly stronger gear wise than the 203 plus a 8:1 super low.
I'd hold out for the Magnum/205. Obviously the Atlas is not meant for big toys and the original Hero case design had issues, since this pretty much narrows it down to planetary boxes I'd go for the strongest.
