8 Low
I see your profile says you're from Nebraska, but I'd swear I saw your truck just outside cokeville, wy this last weekend. Maybe one just like it, but what are the odds? @blazinzuk this is the converted burban I was telling you about... I think.
His is pretty close to the Cummins swapped one I have seen up here
Pinion is (nearly) in line with shaft. Although there is only a couple degrees of angle on the joint at the pinion I think I will reposition my leaf pads & traction bar brackets.... there is just a little hint of vibration at 60 that I want to go away. Also going to cut the C's off the front & clock my pinion up then set my camber & reweld. Unexpected chassis (tuning)
No, down in Texas for a car show this weekend. Been running hard these last few weeks, no time!
I feel ya brother. Hopefully you get some garage time soon so you can install your Woody
