Wow that front pinion angle
The 6 degree shims should take care of that...
Meh, I just ground them down a bit and they are happy now. Good enough.
Yours a 2 joint 1350 shaft?
Fancy headlight adjuster upgrade while the grill was off for the correct front body mounts
Had to order them or standard item at the parts store?I believe they are Ford Aerostar.
Thanks!Dorman 42171
Ordered from Amazon
Lol, I just had the same thought.So I could have Windstar fans and Aerostar adjusters. That would be kinda funny.
How's your CV angle? Keep in mind you'll probably see a little more angle when you drop out the passenger side on a trail so keep an eye on that.
