I have cross over and have no issues, even before I installed hydro assist.
cool.
headin to the craft shop tomorrow to cut and modify some track bar mounts.
thanks for the help today too.
mine is the 2nd gen TNA..... the first gen has been used with several LS swaps already with as much clearance as mine
does pulling the starter give you access to the torque converter bolts so you can apply the proper 44 ft lbs? from my reading, it seems that pulling the starter is neccessary.... i'm gunna give it a shot.
so, next question,
GM 700 R4, 4L60E, 200-4R = 1.125" from bellhousing to converter pads.
what are the converter pads? are they talking about the diameter of the bellhousing inwards to the torque converter bolt holes?
and,..finally..,
http://www.offroaddesign.com/catalog/transfercasemounts.htm
do the steel components need to be painted? they are steel for sure, they look like bare steel?
As for the transfer case mounts, you can paint them if you wanted
was the convertor on the tranny before you bolted the convertor on...?
those bolts loosened up on my 99, I learned the hard way.
For the 1.125 measurement, they mean, if you put a flat edge across the face of the bellhousing, the pads should be 1.125 inches rearward of that flat edge. Like this,
