You can see the centering bit in the picture.
Martin
Martin
DO WANT!!!
Great idea! How do you get it started with no center bit?
So the first layer is the firewall and the next layers being the seats and back wall of the cab?
That was my thought. I punched the holes from the engine bay with a standard holesaw just fine. Since he has the big motor in there already from the cab I guess I can see it. Work smarter not harder![]()
That is not possible. You must have done half the hole sawing job from inside the cab as well. There are at the very least two layers to go through separated by a fair amount of space. That is to say, if you are high enough on the firewall. Low enough, then yes, you could simply just punch through with the hole saw and be done.
I'm going through very high on the firewall. In the cowl area where the wiper mechanism hides.
It was about 3 years ago, and don't remember a struggle.
Not saying it is a struggle to go at it from both sides. Just trying to build a better mouse trap. My cage is already in place and not easily moved. Doing half the work from the inside of the cab isn't practical for me at this point.
I see your running my weathertight fittings, trick...
yeah, we've been using em in boats for ion's.... cool stuff...
get it fired up this week?
I hear ya.. I run across the same issues.. your hearts going "ooo, I wanna see this working", yet the brain says, "eh, get on with the priorities"
take your time on my order if that helps at all, I'm in no rush..
putting a disco there so the engine cage is removable? or just slugging the next section in?
