Pressurized oiling on a manual trans...brilliant!
And thermostatically controlled to boot. I think i'll squeeze a filter in there as well.
... why run a cooling pump?
Sounds like a lot of unnecessary complication and money... why run a cooling pump?
Is fluid temp really a problem on the NV4500?
Past issues lol.
I like the idea of a thermostatically controlled cooler. Never have to worry about operating temps
Dang simple considering the super high tech super high dollar pump lol
It was in his last one
Kert whats your plans for cross-members? Also it looks like you joined the frames at the Fush mount? I'm thinking I will due round tube for most of the cross members except the rear body mount.
I love this thread, 8 pages and the frame isn't done yet... imagine how many pages/posts it will take to reach the "end" or at least running/driving.
All the parts in place for the wheels now. Monday another trip through sandblast and then off to powdercoaters.
Rear axle is in the shop. Bearings, brakes, diff covers, so on and so forth.
Sure is going to he a beastly short box!
man your flying on this thing!!!!
Are those PVC's from Trail Worthy Fab?
I see a thread pop up from time to time about guys wanting to make the PVC piece themselves. This is one of those products, even if you have the equipment to do it, its not worth your time. Sourcing the material kills it right off the bat.
I concur.
Pretty heavy wheels for a DD, not?
Martin
If you are putting speed holes in gussets, you can probably remove the gusset all together and be nearly as strong. Stamped centers would be the lightest and stronger than plate thanks to the shape.Not as heavy as our standard recenter. I shaved the weight on these pretty good.
Our standard wheel center is 3/8" thick. These are 1/4". The gussets have a bunch of speed holes in them. I'll have to weigh one of them.
Was just wondering if punching holes in the PVC piece would make it to weak....
