Likin' those. Who makes them and where did you get them from? Are they DOT approved or offroad only?
they are a little bit bigger and deeper than the factory headlights. As close as I have been able to find.
http://www.ebay.com/itm/4x6-LED-HID...AIR-/251742826936?hash=item3a9d0ab1b8&vxp=mtr
They are bright as hell and very focused. Maybe even a little to tightly focused. I'm kinda on the fence about using them, simply due to replacement availability.
I've been searching for LED headlights since I started this build and unfortunately, as far as I can tell, there isn't a drop in light. The factory bucket for these will not work. A whole new mounting system is gona be required.
If you wanted to check these out I'll add the link.
Truck-Lite (27450C) Headlamp
These have both the high and low beam in the same sealed unit.
Good luck with the search.
I'll keep checking on your progress![]()
Kert that size light is oddball. I have looked and even called companies. It's not a common size not even uncommon it's rare.
Hence one of the reasons I am doing a 73 front clip on my 86. Easy to find all sorts of headlight for the insanely commen 7" round
Cant wait to see the finished product.Have you ever seen when someone swaps the 88-94 NBS headlight assemblies into the 88-91 core support? I've seen pics and it looked clean, just can't remember where I saw them.
