82 K20 CREW "WONTON"
Chinahands
1 ton status
Lincoln, Ne
Chinahands submitted a new Build:
I've finally been convinced to make a build thread. I picked up this truck in January from a friend.
The story behind the truck is a few too many beers, a tree and a big mud hole. It got stuck in a spillway for a pond. Then it rained and the truck sat in 3 feet of water for 2 months.
It was exactly what I wanted and knowing that I would go through everything anyways it was a good buy.
As I bought it.
82 K20 crew cab
350 swap (started life as a diesel)
Nv4500
Dana 60 front
4in spring lift
The plan for it was to build a fun daily/crawler. With it being under water the engine had bent a rod and the nv4500 case had cracked from freezing while full of water.
I'll start with the drive train. So far I swapped in a junkyard 5.3 vortec. Gave it a fresh coat of paint, ls swap engine mount adapters with factory mounts. Lsa exhaust manifolds. Drilled the water pump for the steam vent and mechanical temp sensor. I used an 06 6.0 flywheel and drilled the standard nv4500 clutch for metric bolts.
As for the transmission. The case was cracked and after much searching I found a new oem case. I also decided to replace the mainshaft, 5th gear and input bearing retainer for good measure.
Read more about this build here...
is that the waterline going down the side of the truck? :yikes:
nice progress
Thats an awesome color for the engine, you wouldn't happen to have the code handy would you?
I havent seen a lot of ls swaps with the nv behind them, is that a gm trans or a dodge?
Chevrolet Orange.
How'd the name come about? Looks more like Kung Pao
Ya that's the water line going down the drivers side. The trans is from a 95 gm.
You have some balls trying to resurrect this one :saweet:
wonton = One Ton
I hear the yota guys referring to wontons in this manner anyway.
and some kung pao sounds delicious.
Must just be the lighting cuz it looks really red to me too. Crazy... Looks like a CASE IH red in the pics.
Haha that's funny! Wow I have been in on nearly every off topic conversation in here today... Dang noobs eh...
