me likey raw parts....
It will be similar to the picture above. I'm going to use 2x6 .250 rectangle tube and just notch it to fit the drivers tube and housing and pie cut the end to taper it back to the axle.Interested to see what you do with the truss, I'll probably be copying it![]()
It was a joke. I really don't like MIG weldingWhy is that bad?
Martin
It's alot heavier than I expected. 2x6 .250 with a 1.5 square tube inside of it. Had to brace the inside to keep the 2x6 from collapsing when I cut it open.looks beefy
I'm going to make a template of everything. Might try to get some cnc plasma cut down the roadLooks good! I'll bring my 60 up this weekend for you to do the same on it!![]()
