82 K20 CREW "WONTON"
I'm thinking about doing something like this. I see most truss's for the 60 arnt welded to the actual housing. Anybody know why or if it's a bad idea?
Depending on how bad it is. You heat the tube in the center on the side you want it to move and then quench it with water. The metal shrinks and the tube will move. If it's really bad you have to chain it in a jig, heat it up and use a jack to bend it.
I still can't get over all the goodness in the shop there. You have WAAAAY to much firebird going on in there!:waytogo:
I did something bad today... MIG WELDED... Decided to brace the inner c's while I had it apart. I'm also moving the shock mounts to the top of the upper braces and making shock hoops. I've got to get some 2x6 for the truss tomorrow and then build my ram mount off of that.
