Heath never doubted you, just giving yah crap for not catching the action.
The Buick sounds mean
I figured that, I was just chucking crap back!
I personally can attest to the fact that his family does burnouts...
Yum...Byron...love videos of my "home" track... have you ever went to the World Wheel-Standing Championship in the fall?
Its pretty fun, the last time I went was right before I moved to Colorado. Or the first year a car flip over backwards.....ridiculous.
Bad a$$ dude, one of the cleanest t types I've seen!
Awesome vid!![]()
Just finished the whole thread. Love your truck Heath. Lots of good info. I thought that was Byron. Where in Wisconsin do you live? I'm southwest of Madison. It doesn't seem like there's too many of us on here from Wisconsin.
Wow health I just read this entire thread start to finish. Great job man you have one of the nicest trucks on here.
Thank you. There are a few cheeseheads on here, but not that many really.
Just did the same thing. It was a good read. Looks like you've changed out most of that truck multiple times.
Much more down in the South half. I can think of at least 5 CK5 members, with 2 more moving down there soon. I live in the NE corner (along the Upper Michigan border), and I'm thinking there's nobody else nearby.
Where are ya at, Heath? Would be neat to meet up sometime. We traverse the state diagonally every couple of months or so.
Very clean, I like it
Dude, she looks just like you...
Most people agree she looks like me and oldest looks more like Camile.Very nice.
Any more specs? heads, cam, trans, rear posi/locker?
Every other engine I've ever built I consider mild, this one I do not, I speced and ordered every single part one at a time after I planned the whole engine build for months. It's a pump gas motor with mostly racing parts, but definitely not an all out spread port racing motor, and no titanium or belt drives were used in the making of this engine.
Dart Big M sportsman block
Callies magnum crank (4.75" stroke)
Callies Ultra I rods (6.700")
JE pistons (4.600 bore, 11:1 compression)
Bullet cam (.810"/.778" lift, 280/[email protected], 315/328 adv, 114 LSA)
Crower .937" solid roller lifters
ProGear dual roller timing chain with stamped steel timing cover.
RFD/Brodix conventional rectangular port heads (~380cc ports, 2.375"/1.84" valves)
7/16" dual taper pushrods
T&D shaft rockers
Edelbrock Super Victor II intake (I modified it for EFI and welded in bungs and rail mounts)
Accufab 2200 cfm 4500 style throttle body
Moroso vacuum pump
IGN1A coils
custom 36-1 crank trigger wheel
Holley Dominator ECU
The trans is still the same 4L80E OD trans I built 6 years ago or so. Although I think I need a different converter, this one is strong triple disc 10.5", but I want higher stall
The rearend is a fabricated 9" with a 9.5" 3.60 ring gear and spool with 40 spline strange axles. I am selling the 12 bolt I had in there before with the 35 spline spool.
I've had a spool in it since before I built the 4L80E for it, I had a tight eaton posi in it for years, but sometimes when I drove it to the track if the tires came out of the water box uneven one side would spin and not heat up right, so I sold the posi.
The Holley ECU controls the engine and trans and half the car at this point(both fuel pumps, water pump, both fans, etc) I have sensors all over to datalog stuff during the runs. I can even monitor transmission pressure and temp, oil temp, differential temp, etc. Temp sensors are only $10 to add one once you have the ECU, so I have them all over. With the trans having stock turbine and output speed I can even monitor converter slippage and any wet clutch slippage.
The funny thing is the paint and wheels are exactly the same my father and I did back in 2005 after 10 years of it looking bone stock, so the car looks the same on the outside, but is almost entirely new on the interior and chassis/suspension/steering. I tried to hide the chromemoly cage as best I could, tucked it up real nice.
Nice car! I love g bodies. Ive always wanted a silver T-top monte carlo SS. My youngest will be two the end of this month also. He loves the battery powered mini atv he has.
Nice little 500hp BBC build.
Looks really good man.
