Could be the new ram didn't get fully bled?
anything is possible at this point but it doesn't feel like that to me. When I get it up on jack stands tonight for an alignment I'll go lock to lock a dozen times with the engine off and then on again.
I was just thinking that the ram was something you changed since driving last.
Coming home from camping late last summer it was kinda doing the same thing, I thought it was the 17' canoe on the roof but now I'm thinking it's the same issue.
Leaf spring or linked?
Did you check your bearings?
Mine was doing that for almost a year until I checked the bearinga and tightened them up
leaf springs (52/57"). Have not checked the bearings, I'll add that to the list of things to check.
Front upper shackle bolts were a little loose letting the shackles rock left to right. Took it up to 60+ mph and it felt good. I’ll double check the alignment this weekend, don’t want to tear up the newish nittos.
I run my antenna on a spring like that. It gets folded to a 90 all the time still works great. My buddy put a tennis ball on it after watching it bounce off my hood all day.
Dropped the kiddo off at school, scared a half dozen soccer moms in the process. On the way to work I noticed a little bit of an issue with what feels like steering box slop but then when I make a small correction it feels like it's over steering so I'm quickly trying to counter that. I'm basically playing pinball down a single lane. After work I'm going to look it over closer and double check the alignment.
I'm having a similar issue but I only have crossover no Hydro it feels like a bad rag joint but it's all new, either way even if you wander you truck looks mean! :bow:
Thanks. On the steering issue, have someone turn the wheel left/right as you watch from below. Look for anything loose, sloppy or out of the ordinary. Took me all of 3-5 seconds to see the issue....
