Just realized I didn't add this to my previous post. FWIW, I did -8AN on mine including the cooler from Howe. I also have -12 between the reservoir and pump - they make a pump can with -12 welded on. It's probably overkill.
Have you checked the ram isn't bent?
Any chance it could be too much pre-load on the king pins? I tried the spring eliminators but I thought they made the steering too stiff. I don't know what you're running in that regard and I'm too lazy to look back thru the thread.
Mine is -10 on the feed and all -6 thereafter. Several trucks I know of have the same setup so I can't imagine this is the issue but I'll mention it to PSC.
I haven't looked to closely at the ram but it's pretty new and I've had similar problems with the other ram in the past (both PSC). I guess the king pins could be a factor however I don't see how that would cause some of the problems I'm having. If you can imagine driving down a narrow trail and you need to make a quick left turn and then an immediate quick right, the second motion (right) would have tons of resistance in the wheel. To the point where I have to stop because I cannot make the turn. In general I feel like there is a lack of "assist" over other trucks I've driven with the same or very similar parts but the inn-ability to turn two different directions back to back is the bigger concern.
That definitly seems like a problem in the gear telling which port to have hydro pressure quick enough.
as if the ram is fighting the steering gear.....I guess I could disconnect the ram and set some cones up :thinking:
Back when I first got the assist installed and tried to bleed the system I had the assist lines backwards so when I tried to steer left the wheel would go right and visa versa (ram was over powering the steering gear). Before I could turn the truck off the hydro fluid blew back through the reservoir (cap was off) and all over my shop. After that I noticed the input seal on the steering box was leaking so I sent it back to WTO for a rebuild service.I had bought the WTO box used so that was probably a good thing anyway.
Does revving the motor make any difference? The other thing I would wonder about is the pump but I'm thinking you already replaced that - again I'm too lazy to check.
Might be worth checking how it works with the ram isolated from the system and also maybe with it just unbolted?
The pump and the reservoir are brand new from PSC, this was the first trip on them. Reving the engine does not make a difference from what I can tell. Removing the ram is a good idea.....
That, to me, would be another indication for the steering gear. I've seen people have trouble with a sluggish ram and usually running the RPMs up helps because the pump is pushing a little more fluid.
This is exactly what mine was doing and it was a brand new PSC box along with everything else brand new PSC. It also did the same thing pulling out of my driveway or a parking lot on to the road sometimes. It wasn't terribly consistent though.
Maybe I am wrong, but to me, the slightly improved reaction with the increase in RPM says that the pump isn't moving enough fluid or the pressure is slightly low, or both.
Mine has a stock pressure line from the pump, and just 3/8" lines from the box return to cooler and back to reservoir. I have no problems with how it acts. @Bent77 set me up!! ( when he built the '72) :waytogo:
RPM has no effect on the steering capability. I took it out yesterday to double check that before I call PSC again.
The PSC rep believes the pump is failing again and they're sending a replacement. I'm not very confident that two pumps have failed but it's possible I suppose.
Probably should pull the ram off and see how the system reacts without it before I swap the pump.
no doubt.
I havent read all the way through here but can you get them to bench test it so you can rule out your end? Two in a row is sketchy from a company that's cornered the market for this stuff. I wonder if others are recently having the same problem?
i.e... quality control/out sourcing parts like the way Optima batteries went to shit.
I highly doubt they do anything with them, likely just scrap them for the write off. However they'll fix the pump @ $90 per hour......that's why I just bought a new one a couple months ago rather than have it fixed.
Probably Mexico, they're a Texas company :D
You're probably right. Can you rig your own bench test? Would be interesting to see what numbers it could hit out of the box and then in it's current state.
I would think that you would probably need to check flow, WHILE watching pressure. At least that's what I was taught about diagnosing slow hydraulic circuits.
