Next step was to slide the planetary cluster in the ring, install the used bearing and snap ring however I found my bearing was pretty worn. I'm not going to take a stupid risk like that so a new bearing is on order.
However I could work on the other half of the case.
As you'll notice this case came with the shift fork assembled with a bearing pressed in ready for the 241 shift collar.
The shifter should be moved to the outer position and the shift collar is slid into place
Then you slide the NWF shaft into place
Then I flipped it on it's side and gave the shaft a couple taps with a mallet so it slides all the way into the bearing pressed into the case
This is the backside (t-case side) with the shaft slid into position
and then a snap ring (provided by NWF) is put into place
and top that off with a seal that was also provided by NWF
More to come......
More to come......
. It is a great and honorable profession and the general public has no idea what the job actually involves. In industry, we risk our lives on a frequent, almost daily, basis. It takes a lot of skill and aptitude to do this job well and go home everyday. Now residential electricians are a different animal. They are typically the bottom of the barrel.
