Just makes me tempted to put the locked out distributor on now.
With that MSD unit you're using, did you just install it at 0° and hooked it up to the FiTech?
The crank should be in whatever your base timing position is (10 degrees in my case) and then you drop in the distributor with it pointing to the #1. Then you tell the FiTech what your base timing is (again 10 in my case).
It's easy enough to add later, my HEI cap and rotor was garbage so I just dropped in the MSD distributor.
