brokenparts
Dammit. Seeing that big block makes me jealous.
Yeah that never get old either
Do the yellow tops work ok with your alternator? Just curious because we have seen some charging systems melt down because the owner was using a deep cycle battery. I know the yellow top is dual purpose but wasn't sure if it worked different?
Yeah you would notice the alternator getting hot even in that short of time so it must be ok? I guess now that I think about it a cranking/deep cycle would have to work with your charging system. Nevermind... lolI've used them before without any problem. The truck has only ran for a few 10-15 minute intervals but I haven't noticed anything odd.
If it works good I might get one for mine. We sell them at the shop so I can get them at 6% over cost. If I can sweet talk the interstate guy I might be able to get an even better deal.I'll keep an eye on it either way.
The fire extinguisher is always nearby too.
I like the shock placement. I'll be playing with the same thing soon.
Not the same lolMe too...![]()
where are you placing the shock on the axle?
I have a set of Kert's D60 shock tabs that ride on the inner C http://diy4x.com/product.php?productid=17727&cat=250&page=2
Ooo... I'll have to pick up a set of those. Thanks for the link.
they're pretty slick.....
Optimas are garbage now that they are made in mexico.
they're hit or miss but I've found that most batteries are. I keep a battery tender on this truck, we'll see how it does.
