84 K20 "Ethel" Not an Sbc/NV4500/241C
Semi restoration of a 1984 K20 pickup. 5.3 LS, nv4500, np241c.
I'm all for a slave mount and and pedal conversion as was mentioned a few posts above. Since hydro pedals just go up in price
Yes you are correct.. moving on!
Bolted up the remaining accessories, gates belt and tensioner. Powersteering pulley is also new.
This is the ls7 pilot bearing to be used, it fits the large OD on the crank to compensate for the pilot depth change of .400 so the input shaft is supported properly. Verified it fits both areas upon initial inspection.
My goal is to mate the trans to the engine today and check my clutch throw out situation. Not sure if I need a different fork for the hydro setup or not.
Well some good and some bad..
got the pilot in and the depth set.
The discovered this friggen thing doesn't even come close to clearing. And no I am not gonna play the how hot can my clutch slave line get before it burns the truck to the ground game.. arghhh
No matter if it was aligned properly on the bellhousing it would have even less clearance. Might be forced to buy headers. This is 300$ me to death..
That bracket makes the slave cylinder bleeder hit the engine block on mine. If it ain't one thing it's another. You should really make something that works with manifolds.
