84 k20
Beater/ light wheeler
This truck sags pretty bad to the drivers side (always has the service body makes it worse), so I ordered all new oem ride height leaf springs from rock auto. I selected K30 to help beef it up a bit. I plan to run the new springs with a zero rated on all 4 corners. I grabbed some “cheap” Monroe shocks while I was at it.
For that price you could get the bilstein shocks. 4600 series. Much better in my opinion
Where do you buy them? I can’t find any cheaper than $350-$400 a set. Seems shocks in general have gone up a ton.
I need to double check where I got mine, I was comparing Amazon and ebay, I think it ended up being Amazon .
Ok here it is, now even cheaper
Sorry, my bad, these were for my 98.
I will check for a square
While filling the gear oil I noticed the vent was completely plugged and sheared off flush with the housing. I drilled it out and pounded in a chunk of 1/4” brake line. Hopefully that will be sufficient venting. I finally took this on a test drive, and I should have swapped in 4.10s a long time ago. It drives exactly how I want it to. The leafs seem to ride pretty good too. I never did add in my 1” block to them. I may end up doing that after I get the front springs installed depending on how much higher (if any) the front sits up.
