'84 K5 Build (Midlife Crisis)
Can you take the housing loose off the back of the transmission, then start dis-assembling the 205 on the other end? Take off the plate off the top and see if you can get a visual on anything going on
I assume you have everything in neutral also? Only other thing I can think of is rotating the shafts in opposite directions and see if that will loosen it up.
No, you have to separate it first to get to any of the magnum bolts. I could pull the adapter to trans bolts, but that wouldn’t get me anywhere
Season 2 Nbc GIF by The Office
Next time I have time to mess with it, I’m going to hang it vertically with the cherry picker. Put the porta power spreaders back in and beat the ever living shit out of it with the biggest sledgehammer I own.
First disclaimer... not a lot of experience with a magnum {at least this type of magnum}..........:pimp:
That 465 never did anything to me but can you slide it back together, remove the adapter to trans bolts and CUT the main shaft with a demo saw or something? Then could you slide the adapter off and address the issue first hand?
Is a 32 spline output 465 more valuable then maybe breaking the adapter? In squares they are rare but they are kinda common in 88-91 GMT 400 series trucks.
