'84 K5 Build (Midlife Crisis)
I spent 3/4’s of the day on hell’s revenge with one hub unlocked. Lol
Yeah I tossed a mini spool in it because I didn’t want to spend the money on a ten bolt with the 60 in the works.
makes sense. How are are you going to mount the ram on the 60? Are you porting your own box?
I would have done the same.
Another option would be a power lock, that's what mine has in the front. More aggressive than a posi, but less than a Detroit. And they use to be less than an ARB
Having said that, if I ever change, it will be an ARB up front.
I haven’t looked at mounting the ram yet and I already have a ported psc box from when I did the crossover.
Yeah, I LOVE my arb in the rear, so I’ll definitely match the front.
Fixing the items needing attention from BB18.
Got the spring bushings replaced and everything greased and torqued. Going to dive into the fuel line replacement next.
BOY! Y’all better check your bolts! After all the twisting, almost everything was loose on the ‘ol girl.
Steering box and brace bolts, b-52’s bolts, pitman arm nut (again), I think the only thing that is still tight is the engine crossmember. Haha.
Oh hey we should’ve warned ya...
So ya get those coils and bypasses ordered?
