'84 K5 Build (Midlife Crisis)
Got the ribs in here clearanced. All the grinding and drilling is done now as far as the arb prep goes. I guess it’s truss time now.
So do you silicone the copper line to the case so that it doesn’t rub?
Where the ARB line runs parallel to the case, I blob silicone there and let it set up. Works like a stand off so the copper line won’t vibrate against the case and develop a leak
I never have before, but it sounds like a good idear
to me!
Those new competition ARB’s default to locked position when you lose air too. It’s about fkn time they did that.
6 or 1/2 dozen for me on that. For a broken one that you drive home, open is good. But you are still on the trail
I drive home and I’d rather it be locked going home than get yanked for hours off the trail open. Same reason why I run the Yukon lockouts.
Where'd the stands come from?
They are sunex brand 10 ton. I believe I got them from northern tool. They weren’t cheap. I think they were 250ish but pay for themselves every time I use them.
