mill5471
test drive went awesome, hold each gear out to about 4300 at full throttle and the cruising shifts are perfect. no more early shifts. now its time to weld the rear, a line lock and some burnouts! and hit the local drag strip with some buddys for a good time.
we welded a buddys rear ead about two weekends ago in his ford 2wd f250/460 and while turning sharp sucks, you can do a mean burn out with it...
. hit the strip a while back. burnt a plug wire and was having a little hiccup with the holley i couldn't figure out. o well i was happy, first time i ever took anything down the strip. at least my carbs' problems were consistant lol ran 16.5 all day. actually ran a 16.57 then a 16.53, than another 16.53 all hot laps. not bad for a c30 with my $800 355, the 6.2 rad and my dual 13" fans worked awesome, never even thought about getting hot and my fan controller kept it right temp the whole day.
she's a heavy one.. i was happy with it
