you and me both dave! i'm not sure if i listed the specs of the motor but its 355, TRW 4-valve relief flat tops sitting .027" in the hole, Comp 274H, Edelbrock Performer RPM, (Soon to have) Dart Pro1 heads, Msd Hei dizzy and a Holley 750 Vac sec. i havent ran the numbers but from what ive been told with a standard crush head gasket (.040" i think?) i believe ill be around 10.25 to 1 compression
lower end -already had
cam - uncle had in 327 for about 1000 miles, got it and matched lifters for 100 bucks plus he had the matching comp valve springs still in the box he gave me
carb/intake - both like new, pretty sure i gave 200 for both
dizzy - already had
heads - even grand
Moroso 7qt pan/pick up - 60
already got head bolts, timing cover and oil pan gaskets, just need head and intake gaskets. believe i need the felpro 1003 and 1205 if i remember right..
o and the brown santa dropped my tire groover off 1 down 3 to go! this thing is sweet
edit: haaa almost forgot i still need rockers..
