Before you believe it, verify the odometer and speedometer are accurate. However, that is not far off of what I owed to get on the highway with a 1979 K20 with a 350 and SM465.16.9 MPG.
I'm amazed.
I wouldn't believe it's possible for this truck to get 17 mpg.
Yup, a short bolt with some pipe dope will fix it right up. Don't use too long of a bolt or it will catch the fuel pump push rod.Been driving the ole K20 pretty regularly lately, daily driver duty for the last couple weeks.
The other day I noticed a burning oil smell, and the dipstick was basically dry.
I had oil running down the exhaust and burning, as well as oil all over the starter and fuel pump.
Looking on the front of the block there's two threaded bosses right by the fuel pump, and the top one is dripping oil and is venting crankcase pressure.
At first I thought it was the freezeplug, but it's clean (relatively speaking)
Could it have cracked inside there? Could just putting a bolt in there solve this?
Yep that's the hole that you run a long threaded bolt into to hold the fuel pump pushrod up in the block when changing the pump. My dad taught me to cover the pushrod in grease to hold it in when I was in high school and then I learned about that hole later on.
