85 K30/M1028 Just some simple stuff
Will take some pics tomorrow. Have been working on her through winter. kinda slow. No ground breaking fabrications or inventions. thanks for looking.
Added some cooling to power steering. Old radiator started leaking a little so replaced it
Changed tires to 38/12.50/16.5 TSL Swampers. Had the hydro booster modified by Van . I hate v-belts. Took her out on a little ride. Worked well. Stayed together. Got a couple of dents. Going to add ford shock mounts to front.
How do you like the modified hydroboost unit. Can you tell a difference? I was gonna send in my hydroboost to vanco as well..just so expensive.
Figured out how to get a video of steering and brakes working together. Before mod of Hydro booster I would lose power steering in this kind of place, now it is about same.
Other than hating V-belts,it all seems to be coming together. Went on ride in Lee county ,Ky. Did well until end and the dang belt started squealing some. Little vid of a small mud hole.
Have not done much to truck other than drive it. Did replace the water pump on 6.2, damn that.
Picked up some new tires and wheels. 37x11.50/17 https://tirestreets.com/collections/off-road/products/accelera-badak-x-treme?variant=39285186527290 mounted a black rock steel 17x8 wheels. Used 8oz of ceramic beads per tire.
Rode around town at 31psi and tire measured 37" . Went over to Hollorwood park and aired to 20 front and 18.5 rear - no beadlocks,no spare. Tires pull well. Was able to get up on ridge in muddy ruts and stay there. Good side stability. I like them.
Going down slick steep hills they held better than toyos, going up they pulled very well. Was able to pick lines stay on it. 102_0027.JPG102_0032.JPG102_0036.JPG102_0039.JPG102_0040.JPG
