85 K5 Bogger
Well, ran into a snag with the tractor tires. *What was supposed to be a set... all four have different backspacing. *Different enough that I don't want to use them as is. *So, the 5 ton centers that were welded in when I got them are a waste. *Needs brand new centers now.
Driveshafts are in process.
Driveshaft parts will be in Monday and welded up soon after. New wheel centers will be ready next week.
As it sits now. I want it wide, but not this wide.
How the hell did i miss this....awesome...:D
The 102 wide idea would be good, id hate to swap tires, a friend has 53's on his longbed with rockwells and its about a foot wider. It sucks to have to switch every time you wanna use it.
New centers are coming for sure.
Hopefully they will be done soon.
The left joint is a 1410 for the tcase side of the driveshaft.
The right joint is a 1610 for the axle side of the driveshaft.
I could see them "bitting" harder, but, it would seem that they wouldn't clean out as well either, at least with out a lot of wheel speed. Maybe on a high horsepower truck app they would or could work better that way, but, on a low wheel speed ag type app they would just clog easier :dunno:
Truck looks pretty crazy no matter how the tires are mounted :D
