PsRumors
Last fall I purchased the below '85 Burb. It had a bad engine but a very straight body and clean interior. It is a k20 Silverado and is loaded.
I don't know of another option that could be had on these other than a roof rack. We are talking front and rear air, front and rear heat, rear window defroster, cruise, tilt, power windows, power locks, 4 speed auto and of course quad shocks.
My plans were to find the cleanest cheapest Suburban I could find with a decent exterior color with gray interior and give it a good work over. Wanted something that would tow the boat and haul the family (6) easily. A vehicle I could build and drive at the same time.
I got the 454 in last fall shortly after the purchase and it has been more driving than building. My oldest son Devon is 15. Come August he will be 16 and anyone with a 16 year old kid knows I wont see him near as much between school, work, cruising and dating.
I had an epiphany. Lets build the Suburban. A plan was put together and the Amex was broke out. Below is what we have purchased. Hopefully it will all start coming in the first of next week and hopefully it will be together by the middle of July.
Dana 60 4.10 gears
14 Bolt FF 4.10 gears w/ disc brakes
NP205 Figure 8 bolt pattern 32 Spline input with fixed outputs
4L80e to 205 adapter from Advance Adapters (51-0410)
4L80e (2wd output shaft (24218219) for proper spline engagement) from Bowtie Overdrive
Compu-Shift Trans Controller
Tough Country 2" HD front springs
Below is all ORD;
2 1/2" shackle flip
Front Shackles
Front Upper Shackle Hanger
Front Greasable Bushings
Front U-bolt Kit
Rear Greasable Bushings
Rear U-bolt Flip
Steering Brace
Driveshafts will be coming by way of HAD once we are to a point we can measure.
POR-15 for axle coatings
I plan on udating pictures as we go. Once I have everything here for the axles the burb will be taken out of service, put in the shop and dismantled.
Let the fun begin!!!
Dana 60 4.10 gears
Below is all ORD;
2 1/2" shackle flip
Front Shackles
Front U-bolt Kit
Rear U-bolt Flip
Steering Brace
