So I am finally throwing in the towel with this Professional Products system. A buddy of mine just called and offered me his new Fast EZ-EFI system for a price that's about $500-$600 cheaper than new. The system is still in the box, he is just going a different route. More details to come.
The FAST EZ EFI 1.0 is a good system but it has its quirks and limitations. First thing is no timing control so you need to have a good working and properly set HEI or similar. Next thing is no radical cams, it doesn't handle engines that idle with 10"hg or less.
Also a quirk of all TBI based self learning systems, they tend to like automatic transmissions better as there is less rapid and sudden throttle changes and no sudden loss of load when you press the clutch in while returning to idle. That causes some stumble issues but mostly can be adjusted for.
Additionally, I highly recommend a single plane intake. Or at the very least a large open carb spacer. Conventional hot rodding says single plane intakes are for high rpm only with a penalty of low end torque which is true for carbs but that is not the case with TBI. A large open plenum allows for better low end fuel distribution and actually gets you better low end response. Ironic huh?
That said it's easy to install and easy to setup. It just works, and the more you drive it the better it works. Its light years better than a carb but not quite as refined as factory EFI. I have had my 1.0 system since 2012 and Its only let me down once because of a bad crimp at the battery terminal connection but that's definitely not the fault of the system.
Cost:
Back when the 1.0 first came out it sold for around $2k. Today it goes for about $1k or less due to competition and the 2.0 being more expensive. So if your buddy is selling it for less than $1k, then I don't think you could go wrong.
BTW: the 1.0 system is upgradable. The analog handheld has a new touch screen that it much more user friendly and allows for more fine tuning of settings.
You can also upgrade to a MPEFI set up with the same ECU how ever your harness will need to change.
The ECU is also upgradable to the FAST Dominator Sportsman ECU, plug and play with the ability for laptop tuning and way more parameters.
