I've seen some older dump trucks with plow frames like that. I always cursed them when doing trans or front end work cuz they always seemed to be in the way. Nice setup! I'd like to set up one of my trucks with a plow and dump bed some day for farm stuff.
My old boss had one of those. He used it to haul bull rock out to his ranch to fill in an area of road that had a wet weather stream. Said it worked great.A dump bed would be sweet, I have shoveled a lot of dirt/sand/gravel out of this, and other, truck beds.
Harbor freight has a truck bed unloader that I’m going to try out one of these days, it’s a sheet of plastic that rolls out along your bed, it has a crank that you attach to the end of your tailgate, never used one but it would beat the shovel if it worked...
I was wondering if it was any good, for $35 I figured it would be garbage. I guess I might get it.My old boss had one of those. He used it to haul bull rock out to his ranch to fill in an area of road that had a wet weather stream. Said it worked great.
I'm not sure how much bull rock he took out there in one load. He had a big ol f250. But maybe slowly test it's limits?I was wondering if it was any good, for $35 I figured it would be garbage. I guess I might get it.
I like that. I've got the same plow on my k30. The plow mounts are low and I was kind of wondering about a removable frame.If anyone cares: This is an old school Western Pro-Plow with a cable actuated pump/lift cylinder. Mounting a plow on a tall truck requires fab work to get the A frame positioned correctly. I also have cross over steering which complicates it further because the mounts traditionally go right where my draglink/pitman arm are. I ended up making a frame to interface the plow a-frame that hangs off my leaf springs and goes back under my front axle tubes and then ties into the frame by my trans cross member. It works awesome, and will remove completely from the truck with a couple of pins when I’m not using it.
I built a pump mount that just bolts on to my bumper, I may just leave it on there all the time as a brush guard? I pulled my winch to mount this on my bumper, but it turns out I wouldn’t have had to.
I’ve been keeping a go-Kart track in the field behind my house plowed for my kid all winter with it too, super fun times...
here’s a few more pictures:
Thanks, it has worked out great. The 37” tires make plenty of ground clearance for the plow frame under the axle tubes. I made that frame out of 2.5x2.5”x3/8” angle iron. It seems to be plenty stout for this use.I like that. I've got the same plow on my k30. The plow mounts are low and I was kind of wondering about a removable frame.
Nice work on that
It’s a real dilemma I tell ya. Great things about both long and short beds.Good to see you update this!
I wouldn't shorten it if you haul much a few times a year. I often miss my longbed, though I do appreciate the short bed for some of the daily driving aspects.
But I also like the look of a lifted long bed!
I had a old ranch woman tell me that short beds are useless, as she pulled the tonneau cover over a yard and a half of sand that she I had loaded into her dually. She often hauled material 30 miles up to her ranch that way.It’s a real dilemma I tell ya. Great things about both long and short beds.
You are correct on that. It would be a substantial amount of work. They also look better as long beds with a 12" lift and those giant tires like your blue one. That thing is awesome.One big pro about keeping the long bed is you don’t have to do anything to it. Short bed conversion is a lot of work and time.
I've hauled many many bed fulls of gravel and dirt with this one. It can swallow every bit of 2 yards. This truck was once upon a time registered over 12K GVWR, I think it is on the sticker in the door like that. That hauling ability is the only reason it is still a long bed, extremely handy capability.I had a old ranch woman tell me that short beds are useless, as she pulled the tonneau cover over a yard and a half of sand that she I had loaded into her dually. She often hauled material 30 miles up to her ranch that way.
Good point granny, good point. (Is what I thought)
5ish foot bed for a more hardcore trail rig would be sweet, like MrK5's crew cab. He's got one of the coolest crew cabs on here.Never found anything my short beds wouldn't haul..
Except that dumb 5' bed I had for a bit... That thing was useless
