- Joined
- Jan 13, 2018
- Posts
- 273
- Reaction score
- 963
Thanks! I’m from NW Iowa. You are correct it was my first time at Tuttle Creek, and definitely will not be the last.
I’ll give the hose clamps a try. Good ideaget it balanced. Or you could put a hose clamp on one end or both and rotate them around until the vibration goes away or lessens
I have never heard of that, but I am new to driveshaft building.Does anybody still put ATF inside the driveshaft tube?
That’s interesting, never heard of that but I’ll bet it works. It’ll never rust out either!Basically you drill a hole in the tube, put some ATF in there and weld it shut. I suppose you could get fancy and use an NPT tap and plug. The concept is that the fluid dynamically balances the unit as it's spinning, much like running airsoft pellets or balancing beads in tires.
I've never tried it.
I would gladly purchase one!I have plenty of clusters.
Martin
I PMed you. Thanks a million I’m in no hurry for it at all.PM me your address. Not sure when I will get around to it.
Martin
