OYMC submitted a new Build:
87' GMC Custom Crew Cab Short Bed CUMMINS!
Read more about this build here...
I'll be continuing a write-up that started on 67-72ChevyTrucks.com but was cut short because of a dispute the ended with me being banned for LIFE... IF you care to hear about the drama that unfolded you can read about it in the "Lounge".. If you don't care, I COMPLETELY understand...
I considered starting where I left off but I think I'll begin where I started, cut out the parts that caused this project to take longer than it should have and condense it into a clean "Cut and Dry" build write-up...
So to begin I am building a 1987 GMC Crew Cab Short bed 4X4.
Here are the parts I am using:
2007 Dodge 24 Valve Cummins with a G56 6 speed manual trans and an Atlas 3:1 Gear reduction transfer case
GM Dana 60 front axle with a cross over high steer setup
GM 2WD steering box
Skyjacket 8" front leaf springs, and Skyjacker 6" lift rear
2005 GMC Corp 14 disc brake rear axle
2005 Tahoe power front seats, and rear bench seat
Blazer 30 gallon fuel tank
Toyo 37X13.50X17 M/T tires
Centerline Vector wheels
and a bunch of other fun stuff!
This Crew cab started as a donor for a 1954 Chevy Shop truck build I was working on but quickly realized that I had hidden feelings for this crew cab that I could no longer ignore...
The truck was purchased from a guy who was selling the crew cab for his Dad in Pollack Pines, CA. I was told that all it needed was 2 charged batteries and it could be driven home... When I arrived it had no interest to show even a flicker of life with the two fresh batteries I brought. The guy decided that rater than mess with it just to dump it so the price went from $1500 (Which was still a smoken deal) to $600. When I got home I pressure washed it, found that the positive battery nut on the starter had melted in half, replaced the starter and drove the crew cab for the next 2 months before deciding to move forward on the build.. All the while I drove this old turd of a truck my 2005 GMC Lift Crew Cab with 35,000 miles just sat in the drive way.. It was apparent early on that my heart had shifted and what was once going to be used as just parts would be the center of my fabrication universe....
These are the first photos I took of the crew cab:
