TheBeast_88K5
Banned
Thats ba, right there...
I am glad to see a frame shortening done the right way for a change.
I keep seing people cut it straight and but weld it, the stepped cut you made is how it's supposed to be.
Now did you keep the section you took out?
I am stretching my crew cab and need that section you took out.
I was going to use another frame I had but had to sell it.
I am in Lincoln, CA so I should drive up to Chico and check it out in person.
). With the drive train in place I can also set the proper pinion angle of the rear axle to eliminate potential drive line vibration.
