Thanks Kristi
Yeah, kinda had to just throw it together and get it back up and running... As I finalize the relays, breakers, etc in the box I'll really take the time to route everything super neat and all....
Actually since installing it, I'm up in the air on the lexan... Tho it would be a cool novelty, and somewhat helpful in a diagnosis situation, I'm actually thinking a semi black top would look very cool in it's own right..
The secret black box thing... Plus it would make that corners look "flow" a little better... I'll more than likely just cut/fit both up, and over time figure out which I like better...
This will be how the quick access works for the cover...
The fender-side of the cover will have a length-wise spacer, then a wider one under it, so it slides under the lip... Like a channel... I want it to be easily removable, not hinged....So I can just yank it off...
Then to latch it down on the battery switch-side, I'm gonna run 2 of these in the corners.... Just push em down and they click/latch in, and 1/4 turn and they spring open...
I've used em at work, they're slick.. Done projects with em on lexan, not on the composite, but they would work just as well.
I had considered other stuff, standard Duzs race car type stuff, but dig the look and no tool aspect of the pictured ones....
Or I could always go the mirror of it, satin cup and black handle...
