NEK5
3/4 ton status
Hmm. Yeah, I really like the idea of the bulkheads. As I said, it just seems like it would make it easier/safer to run the hose..won`t have to worry about grommeting the firewall, etc. You`re going to re-do all the heater hoses, right? I`ve never looked at the one on the back of the motor, but I know the one on the rad. clamps on. With using the stainless, I`m assuming it will still clamp, as well as clamping on the heater?I actually think the ano-tuff ends up pricier than the Endura fittings and proflex... The main reason is I want the bulkhead fitting in there... Figure it's the trick, right way to do it...
reusable ends and steelbraided are THE way to plumb.. There's a reason you see it on 7000hp top fuelers... easy to do, not as quick as cutting a hose, but simple... obviously it's a $ investment...
EDIT: Pretty much what I`m wondering, Where do you find use for the elbow fittings when running the heater hoses, and will the AN, or Ano-Tuff clamp on the rad. and the heater, like the rubber hose does? When you run the bulkheads, what will you use on the interior side of the firewall, from the bulkhead to the heater, the AN as well? TIA!
The general public has no clue most of the time...
