Not quite ready for a photo update, but soon I should have some good stuff to post.. I'm about 1/2 way thru the bumper at this point..
But I thought I'd mention another project I'm working out the details on these days..
once I knew I was gonna have OBA, welding and a high end ps pump, I decided I wanted to have a killer belt setup.. so I decided I would run a cog setup similar to what are run in most of the offshore powerboats, etc...
stuff like this...
I do remember someone here runs a cog setup, maybe Greg?
anyway, here's the company I'm using... I dealt with them years ago on a race boat I was working on... way, way quality stuff... they do Nascar stuff too...
http://www.jonesracingproducts.com/
I'm piecing together a custom setup thru them... 2 30mm radius tooth HTD main belts for the major system, and then a 6 rib serp drive off the water pump to run my York... should be pretty trick... the pair of BB's that I rigged, thats what I ran the 30mm RT setup and it was pretty bulletproof and badarse.. apparently the radius tooth also wear about 5 times less than a regular serpentine belt too..
right now, it's looking like about a $400 commitment ballpark for everything I need.. not tooooooo crazy....
the website is a little difficult to navigate, but look around, pretty cool company...
basically I'm gonna have 2 cogs on the crank with guides, one driving the water pump and psc powersteering pump.. one driving the 200 amp alternator and smog pump.. then an addition serp drive in front of the radius tooth pulley on the wp, to drive the york..
would have liked to run full cog, but doing the york clutch, seems problematic...
a real, pic type update should be up next weekend, eh maybe tommorrow...
