So I need some suggestions on Transfer Case options... keep in mind I will not be crawling in it, so low gear usage will be slim-to-none, and 4wd will not be used frequently - I will occasionally drive in the snow on ski trips, and will use when/if I get stuck.
So I have a few options the way I see it...
1. Atlas II or similar - I imagine this will cost me around $2600
2. BW1356 with Advanced adapter to mate to 700r4 - I can get the tcase with a fixed rear yoke. If I buy a reman Tcase and the adapter I will be at $1100ish.
3. NP241 with Drivers side drop, and SYE kit. Again, with a reman this will be about $1100ish.
Also, options 2 and 3 I assume can be done for less if I find a decent junkyard Tcase - I'm just a little leary of that option as I'm basically building the truck from scratch and everything will be new. The Atlas is obviously the best of the 3 options and I can afford it, it's just $1500 that I can spend on other parts of the build that I will probably get more value out of. Let me know if there's another obvious option I'm not considering here.
