Driveshaft took a beating down there.
Mine doesn't have that much axle wrap but I want the traction bar for the driveshaft protection.
There's a place close (1.25 hrs away) similar to that. Not big but a good time all the time type stuff. Where is there located exactly? I'm curious from here to there in miles.
Tuttle Creek ORV Park very close to Randolph, KS.
And kills the frame even faster. I have a buddy with 40's, front locker, and no hydro assist. He just ripped a bolt thru the frame, broke 1 steering box tab off, and sheared a third bolt. And he already had the weld-in frame brace.
Ouch! I wish the steering box modification wasn’t such a process. I really need to do it. Someone sell me a pre tapped box for cheap!
DIY4x front cap that's already tapped, then drill and tap your top cap yourself...I did it on mine 5 years ago in about 35 min and $30 in tools (right size drill bit and NPT tap set) and you're done
You could buy my stuff if you want.
That doesn’t sound too bad
Or, I could show you how to do it. I literally did mine in a weekend. Mounting the ram and all. It's crazy easy.
