y5mgisi
1 ton status
Sweet! Would have been cool to show off the blazer in the mag!
. This is something I've been hearing for years with this truck (3 tranny's is that a coincidence ?) I can make the noise stop by getting back into the throttle just a little or a lot. I know I asked something similar before but I was hoping the new transmission would fix it forever, but maybe it's normal or something else?Tony are all the mounts good/ new? I replaced all u joints because of a similar noise but it ended up being the trans mount. Also another thing to try is to pull the front driveline see if it still does it. Then put it back in and pull the rear shaft. You could have gear issues.
That could be a bearing somewhere in the drive train. Tcase, ring and pinion etc. bring it to the dune party we will figure it out.
cable or VSS?
Total shot in the dark. I hear my cable spinning even though it's a brand new Lokar unit. I hate hearing it.
. I bought a new cover off Diy4x with some other things and planned on installing today. Milky fluid in the rear end and at least some bad bearings. Might be my noise problem? What do you guys think?Check the breather, and make sure it is routed up high. Other than that the 14bolt hub seal/ axle seal could be the only other place. But if that was the case I would think you would have gear oil dripping from the hub, or the axle flange.
. I did get a nice truck tailgate as a Christmas present from my in laws. I got that painted and installed. One thing I love about it is the ease of access to the back and it increased the stuff I can safely throw back as well.
