Can you rent one?
My $200 did the job fine.Yeah I was really floored when he told me that price. I thought about doing it myself, but my biggest hurdle is the air compressor, I just can't justify getting one large enough to run a sandblaster. From what I researched I needed one in the thousand to $2,000 range unless I'm missing something.
Can you rent one?
@centexk5 I had thought about that. There's a really good rental place here that I got a jackhammer from a few summers back.My $200 did the job fine.
If the compressor can't keep up, you just have to take breaks more often that's all.you need breaks anyway
Well I can shut the garage doors and between me and my neighbor we've got a load of tarps and paint covers so we were going to try to set it up in a way where we could catch most of it with the tarps. I've seen the aftermath in pictures. At the end of the day it's just sand or crushed glass but I don't want it all up in my yard.Do you have an open space away from the house? It makes a helluva mess. Also, if you go that route, i would see if you can find 100lb bags of #4 sand. Much cheaper than buying media from harbor freight or tractor supply. I think i pay like 4 bucks per bag
Well this is much smaller than mine but like @centexk5 said you can do it but very small increments.@centexk5 I had thought about that. There's a really good rental place here that I got a jackhammer from a few summers back.
This is the compressor I'm working with. I got it because it I thought it would run more tools than what it actually will. I even have a sandblaster gun and a tiny bit of black oxide. I guess I could try it out but it does say on there it's not capable. What are your thoughts @imiceman44
4.1 cfm won't keep up continuously for sure, but you could use it in short bursts. If you try it start with a full air tank and then stop when it gets too low of pressure, don't keep going.@centexk5 I had thought about that. There's a really good rental place here that I got a jackhammer from a few summers back.
The first four weren't too bad. I thought I had the hang of it until I got to those four in the mount. Glad those are all I lack. It seemed unnecessary to remove all them in the frame considering my intended use.I’m so glad I’ve got a plasma cutter now to tackle rivets.
The one I have seen from ORD is a strap that bolts on the stud then attaches to either side on the frame.We are fabbing today. I think I'd finished but I wasted a lot of time looking for bolts and tools. Tried to do store pickup at lunch while I was with little man and ordered the wrong bolts. Scavenged some for the mock up but it took a minute to find them. The piece I'm making is templated off that other shock bracket I bought for the passenger side from CPI. I have two but the driver's side frame and mount is just too different. I don't really like the ORD option so this is the route I'm going to beef this up. It's got a little twist in it but I can fix that and I'll have to weld up the relief cuts I used for the bends. It's made from 3/16in flat. Since the fuel tank will be in the way once everything is together I'm going to use those threaded inserts and weld them in from the back side of the frame in case I need to replace or service the suspension in the future. They're 3/8-24tpi from RuffStuff. Coarse thread would have been adequate but this was the cheapest option after shipping. I was going to do three but I think two is plenty. Should be plenty strong tio. Definitely better than factory. All I need to do is round up some of the edges to make the piece look nice.
I actually had a pair of those and just didn't like the way they looked and wound up selling them. (I'm OCD and weird.) They were simple in design though and I'm sure they work. Probably any bracketry that adds a second pivot point to share the load is adequate considering the lack of design GM went with in this location. I saw a picture on Google of an even more robust version of what I am making that went to both sides of the shock but I mean I'm not jumping it off cliffs or tearing up Baja.The one I have seen from ORD is a strap that bolts on the stud then attaches to either side on the frame.
Anyways, it's hard to get stuff done with the lack of time I'm getting. I bounced around from the bracket to the power steering frame plate up front. I moved back and forth so I didn't put too much heat into anything. I am messing around up there since I can finally get in there to touch up the welds, and I have a better welder. Wished I'd gotten better penetration on that last weld on the front of the frame though, but it'll be fine considering the braces and the plate make that area rock solid. As for the bracket, it only needs to be smoothed up and the edges rounded out at this point to be done and look pretty. Those threaded inserts were awesome btw.
