Great tip!!! I have jack capable of that.It can be done, you’ll need to support the t case with a jack that can roll forward as you pull it up and out.
I'm very glad it's done. Was really expecting my neighbor to jump at the opportunity to help. I think I called him on the one day he had somewhere to be. About halfway through I went and got my phone and put it back in my pocket so if I got pinched and I could at least try to get to it with my other hand. Also, my wife is pregnant to the point that I'm on standby. I was really glad the baby didn't come in the middle of that LOL!!!Kudos for pulling all that out in one shot by your lonesome! Be careful working by yourself, as long as someone can hear you if your screaming in pain, you’re probably good to give it a shot. We all do it, git-r-done![]()
Those will work fine.I had an hour and a half today to separate the motor from the transmission as well as get the motor on the rotating stand. I had already removed the torque converter bolts and loosened all of the bell housing bolts. Should have been a piece of cake. Turns out the rotating engine stand I got for 60 bucks on Facebook marketplace had actually been used before. Somebody made their own arms, did a pretty good job I might add, but they don't fit any small block GM V8. Got to give the guy a credit, he even painted them to match the engine stand. I had to go over to my neighbors and measure his arms on his engine stand on his small block to tell the difference. I also didn't think about there being fluid behind the TV cable when I pulled it. It made a giant mess. So the motor is supported for the moment but definitely not on a rotating engine stand like I expected.
I've tried every configuration possible. Just for my own psyche I went out and tried the holes you suggested. They're just too short. The more I inspect those arms I can tell they're homemade. We measured the ones on my buddy's harbor freight stands and the arms from bolt to bolt were about 4.5in. These are about 3.5in.Those will work fine.
You just need to use different spots on the engine.
I use the 2 bolts on each side, the lower 2 on each side.
For that kind of money buy the sandblaster, and the media and do it yourself. I have a couple of hundred in my setup and I need maybe another hundred for more suppliesI got a good gut punch this morning. Talked to the blaster, he now charges a $1,500 travel fee. He said he had so many small jobs he had to do that to break it up. Puts me back at square one on finding a mobile blaster to come to the house. He did offer to come load up the frame on the way to work and take it in to the shop on his way to work and then take it back on his way home. He drives by my house on his way to work. It's a really nice offer but I'm not sure how I feel about it. The shops only 11 miles from my house is the crazy thing. Spent my afternoon getting it on the rotisserie. It took the whole afternoon just to get it on there and square. I never got to rotate it.
Yeah I was really floored when he told me that price. I thought about doing it myself, but my biggest hurdle is the air compressor, I just can't justify getting one large enough to run a sandblaster. From what I researched I needed one in the thousand to $2,000 range unless I'm missing something.For that kind of money buy the sandblaster, and the media and do it yourself. I have a couple of hundred in my setup and I need maybe another hundred for more supplies
