'88 K5 - Running Down A Dream
Ground up restoration of my '88 K5. The plan is to go through every inch of the truck and fix or replace pretty much everything that needs it. This will also be a full vert conversion and I plan to make the vehicle look more like a 73-75 than 88.
Almost got it all tacked in. All I lack is the cross bar. My stainless bolt spacers came in for the rear plates, you'll see those pictures too.
I needed a break from the cage so I took the windshield out and of course found rust. I think the driver side will not need any work. However, the passenger side will need a patch. Fortunately, I kept a piece @kennyw sent me 3yrs ago and I have the patch.
Rust sucks, nice Pintails though!
Thanks! A friend of mine in Wisconsin got those and some other G&H super Magnums. Everybody keeps going with new stuff on the public land where we hunt and I decided to go with fewer decoys but go with those giant super mags. We used to run about 300 or 400 decoys, now we can get away with 150 or so and still have the same amount of visibility. So far I've been impressed with the spread I've amassed. The fun part is I get to paint and foam fill with marine foam some of them myself. I'm pretty much convinced that new decoys are all marketing because ducks are not that smart. I painted this one in the picture using mostly spray paint in a little bit brush on paint. All Rust-Oleum.
The cage is done for now. There are some more things I will do to it and obviously I'll officially weld it in once top is on it after the convertible conversion, but I'm glad to take a break from. There are some things I would do differently and I'll probably use some legitimate padding for that family bar in the back, but overall it looks good and should be plenty functional. Heaven forbid I ever actually need it.
I finally decided to use spot weld cutters. I should have picked those up a long time ago. I had always heard they were gimmicky and didn't last long which is kind of true, but they do make the job much quicker and in some ways cleaner if you're going to reuse a panel.
Put a lot of work into this one. Screwed it up on the first shot which really set me back but I don't think anybody will be able to tell that now. I forgot how annoying 20 gauge metal is. So thin. How my welder was almost all the way down on my heat settings to keep from blowing holes through it. My first attempt at smoothing something out. I had to use 2-in disc heads on a drill. Worked out pretty good. Little filler and it'll look perfect after paint.
The convertible conversion has begun. I'm doing it quite differently than most people. I know someone else that did it by removing the spot welds. You may have seen his pics on FB in some of the blazer pages. This keeps the guess work out of the windshield opening and the heat out of the A-pillar. The drawback is it's super tedious in its own way, but the fitment should be close to flawless. The guy that did it sent me well over 40 pictures of the process so I basically have a how-to manual on this approach. Also, if I screw this up, I have a second windshield frame.
Ran into some rust. Shouldn't be many more places with rust at all so hopefully this is the last of it. Spent most of the day doing tedious stuff like getting the braze cleaned out and some of my first cuts cleaned up. I've got the inner and outer skins removed. From here the plan will be to get everything cleaned up well and then transplant the '74 windshield inner and outer skins along with the two end caps over to this truck. This way is more tedious than just chopping it and welding it in, but the overall fitment is going to be really good.
Alright, it's all apart now. I am hoping by the end of the week I'll start welding it back in. There are four pieces total that are in 73-75 convertible windshield frame: inner skin, outer skin, and the driver and passenger a-pillar caps. Got a little rust to clean up, but it should go back together once I get all that cleaned up and the spot weld nibs smoothed.
Still moving forward. This was probably overkill, but I opted to treat the rust on these windshield skins and caps. Started on the lower skin and the caps first. This contraption I made is working pretty good. Also dealing with that rust in the a-pillar. Hoping to have that welded up tomorrow and maybe if I'm lucky, have that inner skin at least tacked. I also went ahead and fitted the outer skin. It'll take some massaging in a few spots, but overall it looks really good.
That’s turning out really nice!
Thanks! It was uplifting to see it clamped in. All the spot welds haven't been too bad. Currently, the most annoying part of doing it this way is getting those rough cuts on the a-pillar passable since there aren't any simple reference points. One of the end caps fits like garbage on both it's original window frame and on the truck and I don't know why. I'm hoping I get that figured out tomorrow.
Today was pretty much all piddly stuff. Got the end caps figured out. No picture of that though. Welded in that piece on the driver side. The big thing was fitting the inner windshield skin before I painted it. It presents its own problem, not one that can't be dealt with. Just caught me off guard. The windshield inner skins from full convertibles are a 1/4 inch shorter in length from A pillar to A pillar. I measured my other windshield frame off of '74 or '75 GMC Jimmy and I measured the original one on the Blazer and the one from the '74 K5 I'm going to use. Both of the full vert inner windshield skins were the same length. You'll see this represented in the gaps in the pictures. No one will probably ever know but me, but it will require me to make sure I get everything dead center or the top won't bolt up without hogging out the holes in the brackets. I find all that weird since they take the same windshield as every square body. An old friend always said these trucks were crudely built.
