Driveshaft looks about perfect now. Surprised on the balance beads...are the tires out of round?
They are no worse than any other 35 I have seen come thru the shop. I may have to have them trued and road forced to get them perfect.
We do not... nothing even close.
Problem is there are no specialty shops that do off-road tires so honestly no one gives a sh*t!
How did they balance yours?
Something is up with those tires, I would call the manufacturer and see what they suggest.
I run around 8 ounces of .20 gram air soft pellets on 37" interco's with no issues up to 65 mph.
I have only owned factory equipped hydroboost setups. My current truck, 89 R3500 crew cab with TBI350, came with the aluminum master cylinder with plastic reservoir. If that's the reservoir you like you should be able to use that for an application reference.
The hydroboost unit I have now I had rebuilt and given a "high-flow" treatment by VancoPBS on Pirate4x4. That was done when I had my 84 K5 and it was a hydroboost I had pulled from another truck that I don't remember what it was. So my current hydroboost has been in 3 different vehicles which leads me to believe there's not much difference despite different part number listings.
Since I've only had factory equipped hydroboost trucks, I've never messed with proportioning valves.
I don't think there's any one hydroboost better than another.
MAX89K5 I was reading through your build, I must say I like it gives me great ideas. I already have an nv4500 in my blazer and planning to do an ls swap. I was wondering what kind of remote start system you used in yours, any info would be a great help
I just bought a Avital 3100LX and plan to install mainly for keyless entry and interior lights while entering. I had an old Clifford in there at one point and was fairly straight forward (but was like 15 years ago). Do you have some tips on color of wires you tied into and location?
Lock/Unlock wires
parking light wire
interior dome light
horn wire
I'll check out your link thread, thanks!
Any other help would be awesome!
I just installed the 4103 in the burb last weekend!
